Repeated use of MgNH4PO4·6H20 residues for ammonium removal
论文类型 | 技术与工程 | 发表日期 | 2007-01-01 |
作者 | Shujun,Zhang,Chonghu | ||
关键词 | Acid dipping Ammonium removal MAP Reuse Wastewater treatment | ||
摘要 | A novel process was developed to repeatedly utilize MgNH4PO4·6H20 (MAP) for ammonium removal from wastewater by releasing ammonium in MAP through acid dipping. In acid solutions, ammonium can be released to solution from MAP while MAP was transformed to M |
![](http://imgs.h2o-china.com/paper/2014/11/2007910113941630.gif)
![](http://imgs.h2o-china.com/paper/2014/11/2007910113942930.gif)
![](http://imgs.h2o-china.com/paper/2014/11/2007910113942265.gif)
![](http://imgs.h2o-china.com/paper/2014/11/2007910113942952.gif)
![](http://imgs.h2o-china.com/paper/2014/11/2007910113942626.gif)
相关推荐
- 两级UASB-A/O工艺处理垃圾渗滤液并实现短程脱氮(英文)
- Nitrifying Population Optimization in Municipal Saline Wastewater Treatment
- Separation of Sulfur/Gasoline Mixture with Polydimethylsiloxane/Polyetherimide Composite Membranes by Pervaporation
- Enhanced Biological Nutrients Removal in Modified Step-feed Anaerobic/Anoxic/Oxic Process
- Characterization of the start-up period of single-step autotrophic nitrogen removal in a sequencing batch reactor
- RES EARCH ON MEMBRANE B IOREACTOR TREATING DOMES TIC WAS TEWATER AND RELATED MECHAN ISMS
