Numerical Simulation of Flow on HCITFB with different Constr
论文类型 | 技术与工程 | 发表日期 | 2008-01-01 |
来源 | 第三届环境模拟与污染控制学术研讨会 | ||
作者 | Yukui,Zhang,Hanchang,Shi | ||
关键词 | Gas holdup; Liquid circulation velocity; Numerical simulation; Static press difference | ||
摘要 | Based on continuity equation, momentum equation and energy equation of mixture in honeycomb cross section inner loop three-phase biological fluidized bed (HCITFB), software “Fluent” is used to simulate the flow in HCITFB reactors with different height and |
相关推荐
- Separation of Sulfur/Gasoline Mixture with Polydimethylsiloxane/Polyetherimide Composite Membranes by Pervaporation
- Effects of adding inert spheres into the filter bed on the performance of biofilters for gaseous toluene removal
- Numerical Simulation of Flow on HCITFB with different Constr
- Baseline Assessment of Water Quality and Circulation Pattern
- The selection of water supply patterns in domestic water sup
- The Consideration on Revision of "Code for Design of Buildin
